ZoneDirector
About power for external antenna for zf7762.
I have a zf7762 using cisco poe switch which support 802.11af poe, i add 2 external antenna in it, can the switch support enough power to run these 2 external antenna?
You are mixing 2 different things. Antennas are passive elements.
The short answer. If the PoE switch can power the AP you don't need to worry about the antenna.
