I have 3 R600s running in unleashed mode and they have old firmware, do I have to incrementally upgrade them or can I go to the latest rev?
I have 3 R600s running in unleashed mode and they haven't had a firmware upgrade in a long time, do I have to incrementally upgrade them or can I go to the latest rev?
nat_nat
Upgrading firmware is one of the easiest things in Unleashed. After you login to Master AP's UI - which represents the entire network you can initiate the upgrade for all the the APs that are part of that Unleashed network. Go to 'Admin & Services->Administer->Upgrade' and the click 'Upgrade' button on your right.
By default, "online upgrade" is selected which means that your Unleashed network needs to have internet connectivity to pull the firmware you want to upgrade to.
thanks
Nat
Thanks, Just wanted to make sure that I didn't break anything when I ran the upgrade command.
josh
