What do you mean the same as your WiFi password?
Just FYI for anyone coming through here later, sometimes Lennar sets up the password to be "Lennar" (no quotes).
Admin
lennar is the password
I have the worst Lennar customer service experience. They send the electrician and did the factory reset procedure. After noticed that the Ruckus WIFI is no listed on the PC, he said I don't know how to work with the network.
What now?
You have to set up ruckus again download the ruckus unleashed app then start on the typical or gateway install doesn’t lennar homes have Amazon services come out and do your setup and add all your devices to the ruckus
Lennar send an electrician and did the factory reset procedure. Lennar doesn't have network service. After that I don't see the configure.mexxxx in the Wifi list. So I can not access the switch condition. I try to get in they the IP but seems to be protected and I don't have neither user not.password
I did the reset on the PoE and on the switch icx 7150. Still not seeing the configure.mexxxx. Any other suggestion?
Is the att router going into one of the center 8 inputs if so then you may not have to reconfigure and just click on manage network admin and the Lennar password the update rukus and see if that works
Hi
I have read through all the above post and feel that the original question is still not answered.
My Set Up:
I have ATT Fiber internet with a BG210-700 Modem. This is broadcasting SSID (for the sake of discussion 'UncleATT76')
There is a single cable going into a Ruckus ICX -C12P. This connects to 2 Ruckus APs Zoneflex 510 Unleashed, which in turn broadcast SSID (for the sake of discussion 'UncleRuck76' )
The ICX wires a wall outlet in my basement which in turn connects to an ATT extender 'Air 4921'which in turn broadcast SSID (for the sake of discussion 'UncleAir76' )
The ICX wires another isolated section of my house which I have connected to an old Netgear NightHawk R7000 Router which in turn broadcasts SSID (for the sake of discussion 'UncleGear76' )
So my questions is;
Please help me in detail if you can for all my above questions.
regards
@bhavin_mehta
I would not name the access points the same as the AT&T Wi-Fi just give them their own unique SSID name and if you ever move in the future rename Your new network with the same SSID so that all your devices can quickly and easily connect without having to reconnect each one. Just remember to reset your access points when you move. The access points are limited to a certain speed that is going to be different from your hard wired and from your incoming speed.
I also forgot to mention that the devices are going to connect to the access point that is closest or that has the strongest signal and your system should spread the load out. I have 23 wireless devices. 12 connected to AP1 and 11 to AP2. I have the same ATT plan but I just deactivated the wireless radio on the ATT modem/router
@sergiosoto78
@Ruckus - Is there a way I can get some more guidance from Ruckus tech support.
I forgot to mention that all the SSID broadcasting devices as mentioned above are quite well distributed in different locations of the large house leaving no dead zones.
I have been able to log on to netgear device and have set it up on an extender/access point, so it doesn't serve as a modem.
How do network engineers set up access points in offices? So when one moves from meeting room to meeting room, they don't have to reset the wifi connections?
I saw some YouTube videos on passthroughs and disabling firewalls, but since i am not an expert, I haven't attempted that.
4 different SSID in a Lennar Smart Home with oversmart devices is a pain.
This did not work! We are currently having the same issue as the author of this post.
