zf7372 will not connect to ZD1100
Initial setup with a ZD1100, 7372, and 7762. For some reason, the 7372's connection request is rejected, thus I cannot add or configure short of the web server login for the AP.
What might I be doing wrong?
Log message re: connection rejection are listed below:
2013/11/02 12:03:04 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:02:59 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:02:54 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:02:03 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:01:58 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:01:53 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:01:06 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:01:01 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
2013/11/02 12:00:56 Medium Model[zf7372] is not supported; connection request from AP[54:3d:37:2c:a6:e0] refused
keith_redfield
Hi, the 7372 requires 9.6.1 or higher so you'll need to upgrade your firmware. This is covered in the getting started guide and our knowledge base.
Perfect - thank you, Keith!
Keith - this is an eval install for continued interop testing with our rugged handheld/VMU product line (intermec). Do I need to go through your Bus Dev or SE group to get access to f/w updates?
keith_redfield
Ah..you should have gotten access as part of the RIOT program, but as a shortcut you can probably use our
warranty registration tool
to get temporary premium account access. As long as at least 1 serial number is recent vintage, it will bump your access level while the 90-day software warranty is in effect.
Keith - we have a new installation of zd1125 and 7372 AP's that came running 9.5.1.0.50. Seems to work, but I'm looking into upgrading per an email that was sent out that's recommending 9.5.3.0.44.
Should I just go to 9.6.1? I'm a big fan of "if it ain't broke, don't fix it".
keith_redfield
I am as well, but both of those versions offer better performance. I myself would do 9.5.3 now and then 9.6.2 when it is released in a few weeks.
