ZoneDirector
First using 7341, few question need to ask
Just get my first Ruckus 7341 today. Using UBNT before with bad experience..
May i know which version is the latest firmware? 9.6.1.0.15?<-default
How can i isolate clients?
What is the function for AeroScout RFID tag detection?
Protection mode should use which one? Protection Mode: Disabled CTS-only RTS-CTS
keith_redfield
9.6.2 is slightly newer, but I'm not aware of any compelling reasons to upgrade for a standalone AP configuration.
Client isolation settings require a controller.
The Aeroscout settings is a particular set of optimizations for those devices. Are you using AeroScout? If not, ignore that setting.
Disabled is the most common setting. The others are used in particular corner-cases or with specific client devices that require it.
Hope this helps!
