Somewhat Tech Knowledgeable need help setting up Wlan after reset
I had to reset my ruckus router (long story), now I went through the setups to setup my WLAN but now I have to walk upstairs near the AP to connect to the WLAN and it says no internet. I have a AT&T modem, Ruckus Router and two APs. Please help.
Can you plug a PC into the router with an Ethernet cable, then look at your CMD: ipconfig output?
That should show you an IP address, network mask, default-gateway IP, and maybe DNS.
You have to configure similar on your APs if you reset them.
