ZoneDirector
Alarm Settings on ZD3050 Firmware 9.6.1.0 build 15
When setting up the email notification, I cannot get the SMTP setting to work. I have tried many email accounts all fail when doing test. I have checked router to make sure nothing is blocking port SMTP port and router is not the problem. I am Network ADMIN for ISP and we have double checked everything. Has anyone else had a problem getting this to work?
Last Month when i set this up I was able to get this to work with same settings. The olny thing different was a firmware upgrade.
This is what the email said last month when I got it working...
"An alarm 'testing alarm' was triggered.
Details:
This is an alarm test."
keith_redfield
Check the DNS settings on the ZoneDirector - it may be having trouble resolving your SMTP server.
keith_redfield
Are you getting just a "Failed!!" message? I do see a bug related to IPv6 and IPv4 being enabled (still open unfortunately). Disabling IPv6 allowed the setup to work so if that's possible would be a good test.
You are a genious. I changed the Primary DNS server to google when we had a problem with our DNS server and forgot to change it back....Thank you much!!
I feel like a noob...:(
keith_redfield
Cool. I have the benefit of being able to access our case histories.
This is the FIX folks!!! Can use my gmail account now.
Thanks Keith
