vSN-e and R500 and policy to choose VLAN by LDAP-setting does not work (on Hotspot-Portal)
I use vSN-e under VMWARE 6.5 with a Hotspot (WISPr) Portal.
Portal and authorisation on a external LDAP-Server works perfect. Also the "User Role Mapping" according the defined LDAP-GroupAttributeValue works well.
But now I would like to give each USER according to "Access VLAN ID" in "the User Role-Definition" an pre-defined VLAN.
This does not work. When I define a VLAN by UserRoleMapping, the AP (R500) does not put the client on that VLAN, but instead uses the VLAN with is defined in the main-WLAN-definition.
Surprisingly, if I change the WLAN-Definition to VLAN-Pooling, it lets the AP uses a VLAN (an I configured my gateway so this works!), but the "userRoleMapping" does not change the VLAN?
So is it possible, to let the VLAN be defined by a policy on an Hotspot-Portal?
Is this not possible in maybe not possible in the essential-version?
does anyone know an helping answer?
Christian
I believe I found the answer myself. On Page 260 on the Admin-manual, it says, that a PolicyAssignment (proxy) for "dynamic VLAN" is for Hotspot not available
π
best regards
Christian
ποΈ All Categories
π Recent Posts
β Unanswered
π Help
