GOOD MORNING, HOW CAN I LOAD FIRMWARE WITH SSH TO AP R700.
GOOD MORNING, HOW CAN I LOAD FIRMWARE WITH SSH TO AP R700. SINCE THE LOOKING DOES NOT START CORRECTLY. POWER LED KEEPS BLINKING. THE DEVICE ANSWERS ME (192.168.0.1) CORRECTLY BUT DOES NOT START THE SYSTEM. THANK YOU
You can access the device via SSH or does it only ping. if power keeps blinking, you may need to open a support case. if you are able to access the device via SSH, perhaps you only need to enable http/https.
It's true, I can login by ssh. I configure xxx: set http / https enable. but even so it does not allow me to administer it. only by ssh
you've begun all of this after running 'set factory' then rebooting the device? What is the AP firmware?
david_black_594
Have you tried a factory reset? Press and hold 8+ seconds. After the reboot try to login with default credentials: super sp-admin
Anusha_Vemula
Hi Joel,
I am not sure of the current firmware running on the AP. However, you can download the standalone AP image from the Ruckus Support portal using the below link.
Once the firmware is downloaded, you can upgrade the AP by referring to the below article.
https://support.ruckuswireless.com/articles/000001551
- Anusha
