ZoneDirector
Cisco Wireless Phones and Ruckus??
Hello
We have a client who is experiencing intermittent issues with their Wireless Phones and we have done a fair amount of troubleshooting to little avail.
Ruckus support suggested to upgrade to 9.6 as they were aware of issues with Wireless Phones.
My question is, does anybody else run a similar setup to us and if so, do you experience any problems??
Cisco CME with 7921 Phones
Ruckus ZD3000 with Ruckus AP's.
We are running the latest firmware on the phones (1.4.5) and the Ruckus is 9.6
The issues are that calls are dropping out, audio is being lost and one sided conversations. The corded phones are fine, it only affects the Wireless phones.
Thanks!
Specifically, please upgrade the Ruckus to 9.6.2.0.13 (MR2) with latest VoIP bug fixes, not in 9.6.0.0.267 (GA) or 9.6.1.0.0.15 (MR1).
Hi
We had this issue logged with Ruckus six months ago and have already upgraded twice on the advice that the next firmware up will fix VOIP issues and this will be the third upgrade so I am very skeptical as to whether this will actually work.
Have you any documented evidence to prove the upgrade will fix our issues or is it just a case of 'We don't know so upgrade'?
I have just read the release notes and the only mention of phones is to do with 'Ascom/ALU 8118 IP Phones dropping connections during roaming'
I am not going to upgrade (again) for the sake of it without more evidence that issues specific to our situation have been fixed.
keith_redfield
Hi Laurie,
You're point it well taken. While 9.6.2 has a number of generic VOIP fixes that *might* address your issues, there are also environmental, and best-practice guidelines that must be taken into account. Here on the forums, it's not practical to address all of those complexities, and so the best course of action is to open (or re-open) a support case to make sure all variables are addressed.
I had a similar issue and it was an interoperability problem with Cisco's power save mode (U-APSD/PS-Poll) and the Ruckus AP.
If you turn off the power save option on the Cisco handset, the issue with one way audio and dropped calls is resolved. Phones will drain their battery faster however.
More info on my blog - "One Way Audio on Cisco 7925G Wireless Phones"
http://networkcanuck.com/2013/10/04/v...
I hope this resolves your issue as well.
Hi Rob
I actually found your guide last week
I have literally just updated their Zonedirector to v9.6.2 as Ruckus advised this fixes the issue with the Power Save modes. The vessel have not thoroughly tested it but the first call dropped audio which is not a good start....
I need to check which phones still have Power Save on and confirm with Ruckus whether it should be on or off for the 9.6.2 firmware.
Laurie,
9.6.2 did not resolve the issue for me. Only disabling the power save mode seemed to work. Of course this was for a different phone model so it may be different for the 7921.
I have since upgraded to 9.7 and plan to test with U-APSD/PS-Poll enabled again.
Good luck!
Rob
Hi Rob
I was hoping 9.6.2 was going to fix the issue but from the initial tests and what you have said, that may not be the case.
On quick question, was this issue evident on older firmware releases?
The vessel said the phones were 'rock solid' when they were using the original firmware that the ZD came with but as soon as we upgraded them to a later one (at their request), the issue started occurring so I am thinking this issue was introduced in a firmware update.
Laurie,
I'm unable to say for sure if a previous version had the issue or not. I can tell you that we didn't have the issue on the 7925G phones when they were initially deployed and it was reported to me sporadically over time as people started noticing problems. I don't know what firmware version we were on initially, although I do tend to upgrade as versions become available.
For me, rolling back to an old version wouldn't be a good idea as we are in need of some of the additional features in 9.7 (Bonjour gateway, etc.).
Rob
Yeah we didn't want to roll back either but the issue does seem to have occurred after a firmware 'upgrade'. Cisco Wireless is my background so Ruckus is a little alien to me. I can't help thinking it would have been fine with Cisco Wireless....
I am going to go back to Ruckus (again) and ask whether they think the Power Save should be on or off and go from there.
Thanks for your help
Yes it's a little unfortunate that so-called "standards-based" options don't function properly in a multi-vendor environment.
This is the exact issue I am seeing today. We have just upgraded to Cisco 7926 and they are just unstable on the Ruckus WiFi. no power saving & tried 2.4g & 5g Have just opened a ticket with support. we are on 9.8.3.0 build 14
