I have got issue within this below
-2.4 dan 5 ghz enable some windows connect successful ( 802.1x authentication)
-2.4 Ghz only some windows successful connect ( 802.1x authentication)
-5 GHz Only windows can not connect ( 802.1x authentication)
-Windows connect 5ghz only using preshared key SSID, can connect successfully.
macOS with 802.1x authentication always disconnect while walking away from AP, roam not successful.
note: we are using ZD1200 , firmware 10.5 build 190,
kindly need help to solved this issue, thks so much before. any body can help ?
