ZoneDirector
Help with ZD1100 firmware upgrade path to 9.10.2.0.53
I have a zd1100 with 12 7982s that i would like to get to its latest firmware 9.10.2.0.53
It is currently at 9.7.2.0.9 Following the upgrade path docs , I can't seem to find the proper versions of FW to get there. Which ones should i apply to keep my config intact?
Going backward from the version you want to end up with, 9.10.2.0.53 Release Notes say
you need at least 9.9.0.0.205 (GA) to upgrade to this version. And 9.9 (GA) Release Notes
say you can upgrade from 9.7.2.0.9 (MR2), so you need to go thru 9.9.0.0.205.
https://support.ruckuswireless.com/software/675-zd1100-9-9-0-0-205-ga-software-release
Thanks!. That worked a treat.
Happy to receive your positive results feedback.
