Hotspot configuration problem with CA
ha_an_nguyen
Hi all!
I'm configuring Hotspot and having the following problem (figure)
Does anyone know how to fix this problem?
Thanks in advance!
syamantakomer
Hi Nguyen,
Cert validation is showing that root cert is not self signed and that is why cert import will fail.
What cert you are using, wildcard or standard?
Make sure you upload the cert chain properly in ".cer" (base-64 encoding) and private key in ".key" format.
Syamantak Omer
