Upgrade problem vSZ 5.1 to 5.2
Trying to upgrade to 5.2 from 5.1 but the upload just stucks on 22%, tried restart cluster and restart of host but no difference. Any ides?
albert_pierson
Hello Jonas,
Is this a single node or multiple node cluster?
Were all nodes in service when the upgrade was initiated?
Did you verify that you had sufficient resources for the version of code ... this information is listed in the upgrade guide for 5.2:
https://support.ruckuswireless.com/documents/3139-smartzone-5-2-0-0-699-ga-upgrade-guide
And here is a link to the release notes which may have some caveats.
https://support.ruckuswireless.com/documents/3138-smartzone-5-2-0-0-699-ga-release-notes
To figure out what went wrong it is best that you create and save diagnostic snap shots for EACH node in the cluster.
To actually save a copy of these files on each node you can create the diagnostic snap shot from the SZ CLI:
en
diagnostics
show snap (show previous snap shots)
execute all (create new snap shot)
The snap shot can also be created from the GUI in the Diagnostics::Application logs using the "Download Snapshot logs" button. This creates the snap shots and downloads it to the browser but will not save it on the system. It may fail if the system is busy as this file can be very large.
If you saved the snapshot using the CLI command - it can be downloaded from the "Diagnostics" tab under Application logs. Click on the number link next to the log name to open the list of contents then click on the snapshot name to download it.
This file is compressed but not encrypted so you could open it up using a decompress tool and dive through all the logs, but I suggest you open a ticket with Ruckus Support to help get the problem analyzed.
I hope this helps,
Albert
