SZ 3.6.2 and WLAN Group VLAN Override - greyed out
Greg_WiGuy
Hi Gang,
I'm trying to figure out how to use the VLAN Override feature on a per WLAN basis under a given WLAN Group. The feature is there but it seems to be 'greyed out' with the word Default and isn't modifiable.
I've searched through the SZ 3.6.2 Administrators guide to no end finding any mention of the VLAN Override feature anywhere - no mention of the feature under "Working with WLANs and WLAN Groups" when trying to comb through the sub articles manually.
sanjay_kumar
We should be able to modify the VLAN of a particular SSID from a WLAN group.
The VLAN section should show as a number, not as "default".
Can you please provide us a screen shot of what you are seeing?
Greg_WiGuy
Hi Sanjay,
Here's what I'm seeing
Greg_WiGuy
Hi Sanjay,
Here's what I'm seeing. I'm unable to edit the section under VLAN Override or NAS-ID
sanjay_kumar
You have to click on Configure, at the right top on the Configuration section >> then you can see the VLAN Override option.
Below is the picture.
You can also override the VLAN, on the individual WLAN if you select the WLAN >> Click on Next >> Configure >> Advanced options >> Access VLAN
Greg_WiGuy
When I click the configure button as you have I get a different window which lets me choose which WLANs to add/remove from the group but no options for vlan override. We don't want to change the vlan the WLAN uses globally for other WLAN Groups, just a single group we can assign to a specific APGroup/Location.
sanjay_kumar
You should click on "Next" to get the VLAN config window.
