ZoneDirector
Building a wide range wireless network
I need to build wireless network to cover a 6 square km s village,
can you recommend which are the best router and antenna s to use?
keith_redfield
Hi Maamoun,
Outdoor municipal networks are very complex installations. I would recommend you seek out a qualified authorized Ruckus VAR in your region.
http://www.ruckuswireless.com/buy/par...
-Keith
