Multicast and UDP stop streaming issues:
Hi All,
I've been having major issues with a Hotel/Property running ZF7363's and R500 AP's in the rooms. AP's need rebooting almost daily.
They have a IPTV solution that connects to the AP as there is only 1x Cat5e cable available to each room.
The Edge switches being used are HP5130 POE switches,
The Samsung TV's being used are Samsung AD690's hotel tv's. The TV's stream perfectly for a couple of hours and then the udp/multicast steams stop. I still have full bi-communication with the TV over the network, but no streams seem to pass through. Only after a ap reboot the streams start working again.
I have added a the following config onto the ZD3050 for each AP model being used.
Ruckus(config)# ap-group system default
The AP group entry 'System Default' has been loaded. To save the AP group, type 'end' or 'exit'.
ruckus(config-apgrp)# model r500 port-setting
ruckus(config-apgrp-port)# lan 2 qos igmp-snooping
ruckus(config-apgrp-port)# end
and
ruckus(config-apgrp)# model zf7363 port-setting
On the ZD controller i have configured LAN 2 to be an access port to Vlan 5 - which is the IPTV vlan.
The Controller is currently on Version
System View
Uptime= 339d 12h 53m
Model= ZD3050
Licensed APs= 200
Serial Number= xxxxxxxxxx
Version= 9.10.1.0 build 59
Some assistance will be hugely appreciated.
Thank you in Advanced,
Shaun
