I strongly suspect that Ruckus can't handle private keys in EC format (unlike RSA). My problem is as follows:
I am attempting to install a new custom certificate from Let's Encrypt created by the acme plug-in on pfsense. The certificate create process executes without a hitch and I have valid files: <fqdn>.{crt, key, fullchain, ca, all.pem}. The certificate is using EC which LE is now generating in production and most of my servers can use them without issues.
However, when I try to import the crt and key using the Unleashed interface, the error that is returned states that the private key does not match the certificate : "The imported private key still does not match your imported certificate. The imported certificate and private key will be discarded. Please import certificate file again."
I have also imported the <fqdn>.ca file as additional trusted CAs in the Advanced tab.
The key file has the following format:
-----BEGIN EC PARAMETERS-----
B<altered data>==
-----END EC PARAMETERS-----
-----BEGIN EC PRIVATE KEY-----
MIG<altered data>=
-----END EC PRIVATE KEY-----
The key file passes an openssl check as follows (altered data):
openssl ec -in <fqdn>.key -check
read EC key
EC Key valid.
writing EC key
M<ALTERED DATA>=
The cert (<fqdn>.crt) passes an openssl check with the 'Signature Algorithm: ecdsa-with-SHA384'
As an aside, I have tried both manually importing the certificates through the Unleashed GUI as well as the cool script referenced here (pfsense -> acme -> unleashed): https://github.com/ms264556/Hackery/blob/master/pages/PfSenseLetsEncryptToRuckus.md
