Wireless lan
Good Evening, If I create a new SSID inside SmartZone is possible to define that this SSID must work only on 2.4ghz or 5ghz and not togheter?
Giuseppe
Hi.
Sure, at least there are two ways for that:
1. Switch off the 2.4 or 5 GHz radio at all. This will disable all SSID on the radio.
2. Use different WLAN Groups for 2.4 and 5 GHz radio and associate it to the required radio. In this case you have to add the mentioned SSID in the group which you will attach to the radio (2.4 or 5 GHz).
Sorry but I did not understand ( I am new with SZ ).
For example I have 2 AP ( AP01 and AP02 ) and 2 SSID ( default group )
VOICE = 2.4 GhZ
DATA = 2.4 and 5
I have to create a new group with SSID VOICE ( 2.4 ) and another group with SSID data ( 2.4 and 5 )?
Is it correct
Thanks in advance
Giuseppe
First of all you have to do next steps:
1. Create two SSID Voice and Data.
2. Create two WLAN Group: WLGRP1 and WLGRP2 for example.
3. Put or add VOICE SSID into WLGRP1 and DATA SSID into WLGRP1 and WLANGR2.
4. Go to default AP Group with two APs, then find how to Edit it. After that you will see that on each radio interface you can override WLAN group to another group and change it as below:
- For 2.4 = WLGRP1
- For 5 GHz = WLGRP2
5. Save it.
Hope it will help.
