R710 upgrade problem
yorgo_xudous
Hi, I have 6 R710 APS on an unleashed network. I am on 200.7.10.202.92. When trying to upgrade to 200.8.10.3.243 from the admin menu, i get to the rebuilding unleashed network screen and then it reboots back to 200.7.10.202.92. I tried both online and local upgrade but the formware stays stuck on 200.7.10.202.92.... Does anybody have any suggestions?
victor_gonzalez
Hello, the release notes document indicates that it must be updated to version 200.7.10.202.94, in order to update to 200.8.10.3.243
To upgrade to 200.8 using the online upgrade method, your Unleashed network must be running 200.7.10.202.94. If
your network is not running this version (200.7.10.202.94), please upgrade to this version firts.
Regards
yorgo_xudous
Ok nevermind I solved it by unplugging all APs except the Master, upgrading only the master and then replugging the other APs. But as a side note, I was able to upgrade to 200.8 directly from 200.7.10.202.92.
