My switch will not stay powered on after resetting everything multiple time the switch will power on for a short period of time then turn off again. Any direction for this issue. The unit is less than three years old.
It is probably hardware issue, I never seen switch powering down because of some software problem.May be Ruckus rep knows different?
Good thing is that you have LTW warranty, so you can RTF the switch.
Hi Eddie,
I would suggest to open a support case.
Also, try if you get access for some time, if yes, pull the "show tech" and "support save" information.
