ZoneDirector
Problems with Hotspot and mobile
Hello! I am facing problems with Hotspot. Everything is set up and working when access is done from a computer, when access is made from the same cell does not work. Connect the network however is not directed to the login page.
Thank you.
keith_redfield
Hi Marcos,
You haven't really given us enough information to work with. From what you have said, the issue is most likely with the way the cell phones are provisioned. I would recommend that you open a case with our technical support team.
Hi Keith,
Even after reviewing all the settings the problem continues. What I noticed was that the problem happens with some versions of the Android operating system. The test results were negative in version 2.3.
Can you help me?
The version of zd is 9.7.1.0 build 30.
Hello, Even after reviewing all the settings the problem continues. What I noticed was that the problem happens with some versions of the Android operating system. The test results were negative in version 2.3.
Can you help me?
