ZoneDirector
AP Does Not Connect to a Controller
I cant make the Ruckus AP 7762 with a Controller Zone Director 1100. I have others AP in production, with same configuration.
martin_martin
Hi Suporte
Please login to the AP and provide us the version that is running on the AP.
Then we can check further.
kind regards
Martin
ZoneFlex 7762 model outdoor APs are supported on ZD firmware 8.1 to 9.8.3, but not on 9.9 and later.
on the controller, when AP fails to join, it will publish error message or log on the failure reasons...
it would be a good starting point
firmware version on the AP does not matter if controller running firmware 8.1 toΒ 9.8.3 will upgrade/downgrade the AP to version which will work with controller..
ποΈ All Categories
π Recent Posts
β Unanswered
π Help
