Outdoor R710 Power Adapter
Need a power adapter for the outdoor model of the R710. Can't find any information on this, anywhere. Anybody have a link to buy one? Know the name of it so I can search for it? Thanks.
Hi there,
R710 is not an outdoor WAP. Regardless, the power supply part number is always in the Spec Sheet. Here is one for R710:
https://ruckus-www.s3.amazonaws.com/pdf/datasheets/ds-ruckus-r710.pdf
Cheers,
Alex
T710*. Sorry.
T710 Does not support a power supply. Your best bet would be a PoE injector or a PoE enabled switch. Check under Optional Accessories: 902-0180-XX00
Here is the Spec Sheet:
https://ruckus-www.s3.amazonaws.com/pdf/datasheets/ds-ruckus-t710-series.pdf
Cheers,
Alex
The T710 clearly has a four-pronged connector similar to Cisco three-pronged connector for outdoor APs.
