New Zoneflex R500 does not power on
mike_guidry_dqy
I have a NIB Zoneflex R500 that does not power on over PoE. I am not sure if I am doing something wrong, or if the item is DoA. I have tried connected to the router, and to the wall jack, but the lights do not turn on. Am I doing something wrong?
If you have tried different PoE switch ports, and two different cables already, you may need an RMA.
mike_guidry_dqy
How do I verify that the switch ports are PoE capable?
mike_guidry_dqy
I use different consumer level PoE switches, Trendnet, Linksys, which have 8 ports, 4 of which provide PoE out.
They should be marked somehow on the front of the switch typically.
On the AP, the R500 has two Eth ports, only one says PoE over it. Be sure you are plugging your cable into the
PoE in Ethernet port on your AP too.
What type of switch do you have? Check the manufacturers specs, I presume you are plugging into the POE port on the AP?
mike_guidry_dqy
It is in the correct port, but I guess I am unsure if this device supports PoE. I am using a
Netgear AC1750 Smart WiFi Router
, and it connects directly to the Ruckus. Should this be able to power the ZoneFlex
No, it doesn't appear that the NetGear wi-fi router has PoE to its Eth ports.
Number of Ethernet Ports
Five (5) 10/100/1000 Mbps—(1 WAN & 4 LAN) Gigabit Ethernet ports
Try eBay or Amazon, search for '8 port PoE switch'. I see them as low as $26.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR4.TRC1.A0.H0.X8+port+poe...
New, in-box, for $20...
https://www.ebay.com/itm/Airlink-ASW308P-8-Port-10-100-POE-Switch/282927803354?epid=11003221563&...
