I’ve got ZoneDirector 3000 with ZoneFlex 7363 APs, with two
WLANs – Internal and Guest. I have changed my IP addresses on the network and
would like to change wpad.dat on ZoneDirector to point to new proxy server IP.
I navigate to “Configure” – “WLANs”, click on “Edit” my Internal network, click
“Advanced Settings” and in “Auto-Proxy” it set to Wpad.dat that is saved on
ZoneDirector with address http://xxx.xxx.xxx.xxx/uploaded/wpad.dat.
I clicked on the link and downloaded wpad.dat file, changed IP addresses and
saved it on my PC, clicked on “Browse” button selected my new wpad.dat file and
clicked “Import”, I get a warning that wpad file will be overwritten, clicked OK
and there is no change. It would not replace the file. Is there a way of
removing the wpad.dat file from ZoneDirector or somehow force it to replace it?
Can it be done using Command Line Interface?
Thank you.
