AP R720 - Power options. Using PoE (802.3af) or PoE+ (802.3at) power options:
Using PoE (802.3af) or PoE+ (802.3at) power options - Data sheet indicates 2nd Ethernet port & USB disable.
R720 has two ethernet port options: One 2.5Gbps Ethernet port and one 1Gbps Ethernet port .
Which one is disabled or can that be the users choice?
DarrelRhodes
Hi Jim,
In the case of the AP running in low-power mode; it will be the 1Gbps Ethernet port that is disabled, as low-power mode relates to PoE and only the 2.5Gbps port is PoE enabled.
Please note the 2.5Gbps port can run at 1Gbps speed.
HTH,
Darrel.
syamantakomer
Hi Jim,
Below is the power vs operating characteristics table.
For more info, refer R720's data sheet from
here
Syamantak Omer
