Hi, I have had 2 Ring cameras connected for well over a year to our ruckus Wi-fi fronted by 4 unleashed R310s. No issues at all. Last week one of them lost its connection and wouldn’t reconnect. Helped by Ring support they asked me to reboot everything, zero the ring Camera settings and add it again using the Ring App (as I had done originally). Every attempt has failed since with incorrect password and yet I know the password is correct (have seen it in other device to check it’s working and it is). I have subsequently successfully connected camera to two different mobile phone hotspots with the same password. Weird. So why is the authentication of the password failing on the Ruckus? And why now, not before. To make it even more weird. A couple of days the other camera has done exactly the same. So neither camera will now connect because Ruckus fails with ‘code 15 error in frame 2 of 4 way handshake’ incorrect pass phrase (invalid MIC).
First of all anyone have suggestions?
I did wonder if either Ring or Ruckus are rolling out updates that have caused a new issue encountered when a camera loses its link?
both cameras down rules out hardware and they were bought 12 months apart.
did wonder if sidewalk may be a factor but I am in the us and don’t think it’s live over here. Very confused layman.
any help or pointers appreciated but I am assuming that whichever it is that it would surface on here and would be understood. Thanks.
