using ruckus unleashed: 200.9.10.4.233
I am I missing something with this qos igmp-snooping command or using it incorrectly? trying to disable IGMP Snooping
ruckus(config)# ap-group "system default"
The AP group entry 'System Default' has been loaded. To save the AP group, type 'end' or 'exit'.
ruckus(config-apgrp)# model r750 port-setting
ruckus(config-apgrp-port)# no lan 1 qos igmp-snooping
Please input the port number , and then try again.
ruckus(config-apgrp-port)# show
PORTS:
LAN ID:
1:
Enable LAN = Yes
LAN Type= trunk
Untag ID= 1
Members= 1-4094
Guest VLAN=
Enable Dynamic VLAN= Disabled
802.1X= disabled
DHCP opt82= Disabled
Tunnel= Disabled
MLD Snooping= Disabled
IGMP Snooping= Enabled
Directed Multicast= Disabled
2:
Enable LAN = Yes
LAN Type= trunk
Untag ID= 1
Members= 1-4094
Guest VLAN=
802.1X= disabled
Tunnel= Disabled
