ZoneDirector
upgrading problem
hi, i have problem when i want to upgrade zd1100 firmware from webgui, uploading file sofware takes too long (more than 1 hour) and its not done. status still uploading not change to upgrade, can anyone give me advice for this? im using ZD1100 (9.8.1.0 build 101) and want to upgrade to 9.9.0.0.205 and upgrade again to 9.10.0.0.218
many thanks
marutha
martin_martin
Hi Marutha,
I suggest you reboot the ZD1100, that will clear up some more memory.
Then retry.
regards
Martin
halo martin
thanks for your advice, but i already do that and its not solved my problem. And i already did erase all event and all alarms too,,
regards
marutha
sometimes it helps just simpy use another browser.
yup thanks thomas, its done using IE
I recently had this issue and Support had me download Firefox 45 and then surf to about:config, search for and change security.tls.unrestricted_rc4_fallback to user mode. I just clicked on it once to change it and then I saved the settings and performed the upgrade and it actually worked slowly but surely. I went directly from 9.6.1 to 9.8.3.0.44
hi jeff
u can actually u can using internet explorer instead, so far i got no prob when upgrade ruckus using it,
thaks by the way for give an adivse to troubleshoot upgrading using firefox
You were lucky! I was first using Internet Explorer and twice it failed. It hung at upgrading 0% and never continued. The ZD1100 status light quickly began blinking red and never changed. That's when Ruckus support knew to have me download Firefox 45. This is why I went ahead and shared how I finally succeeded. Thanks!!!
