Hello!
I hope somebody can help me out! I'd like to convert one of my wifi network from PSK to DPSK. I'm using a ruckus r710 AP unleashed. I'v read some ruckus articles, and even watched not just the Ruckus Education "DPSK WLAN Configuration Release 18.02" video but a Polish Language video on Youtube and still unable to make it work. What i've done so far:
- i've chosen the wifi network i'd like to configure >> edit
- Name: unchanged
- Usage type: Standard
- Authentication Method: Open
- Encryption Method: WPA2
- Password: entered a passphrase
- Accounting Server: Disabled
Advanced Options (under Zero-IT & DPSK)
- Dynamic PSK: internal
- DPSK Lenght: 16
- DPSK type: Mobile Friendly
- Expire D-PSK: unlimited
- Limit D-PSK: not ticked
- Shared D-PSK: not ticked
Under Admin & Services >> Services >> Dynamic PSK
- Target WLAN: the wifi network i wanted to configure (the only option, because other networks don't use DPSK yet)
- Number to create: 1 (just for my test laptop, running win10 2004)
- Generated the CSV file, then downloaded it.
I think till this i'm OK?
I opened the CSV file in LibreOffice Calc, added a username, and changed the MAC Address of the laptop. First problem is that the generated form uses wrong column? When i clicked to upload profile, there was an error, because the second column is not the mac address's column in the downloaded format, but the column of the passphrase. So i changed to this: username, MAC address, Passphrase, WLAN name, Expires. After the change i could upload it, and it appeared under the Generated Dynamic-PSKs. After that i tried to connect to the WLAN with my unique password generated by unleashed, but i couldn't connect to the network, but i could use the WPA2 preshared key, and i was able to connect to the network.I thought maybe the problem is that the win10 uses private random MAC address, but i copied the MAC address from my router's DHCP table, and checked with ifconfig /all, the 2 was the same, and i have no option under settings to make such a change.
So this is what i could reach. I hope someone can help me out what am i missing here.
Thanks any help you can provide!
ps: please excuse my english!
