ZoneDirector
Zero-IT and dpsk configuration issue
Someone configured the zonecontrooler 1106 to work with Zero-IT Activation and the Iphone?
I follow the manual release 9.6 but I am not able to connect to this Wlan
thanks
Giuseppe
keith_redfield
This document may help:
http://theruckusroom.typepad.com/file...
Can you upload a screenshot of your WLAN configuration? (blur or mask any sensitive info). Also provide more detail like
I CAN connect to the provisioning WLAN
I CANT download the app to my phone
etc
There are several configuration steps required for success. Are you connecting first to the provisioning WLAN? From there, you should get an option to download the provisioning app to the phone. Without that app getting installed, you won't connect.
Also make sure you are using a broadcast (not hidden) SSID. For reasons not yet clear, Zero-IT doesn't work in that situation.
SmartZone
