AT-0636-VH antenna kit question
The AT-0636-VH bundle of two external omni antennas includes one vertically polarized and one horizontally polarized antenna. I would just like confirmation that these two antennas are designed to be placed on the same AP together, assuming the AP is an appropriate model? I have a 7762 (not sector, the omni model) that I'd like to try this antenna bundle on to see if there is range improvement, but I want to be sure first that adding one VP and one HP antenna to the AP won't do crazy things to the AP itself.
Thanks.
Hi Lonnie,
You can connect the antennas to both 5GHz connectors on the 7762, and it will recognize
the polarization. You do want one vertical and one horizontal antenna, as you have. Good
luck and best regards.
Perfect, thank you.
