galbicka,
Interesting scenario. What is your overall query, and what end result(s) are you looking to achieve?
"I have verified it. By default the IPv4 is enabled for ZDin the Setup wizard and for APs it is IPv4&IPv6. I agree with your pointthat the default settings need to be changed. You can contact your local SE toraise an FR(Future Request) so that it may get fixed in the future firmwarereleases or if you want I can forward your contact details to the SE. Fornow,the work around is to manually change the IP version as IPv4 only for theAPs or to enable IPv6 support for ZD to restrict the IPv6 Clients."
