My ISP has a max download of 300 Mbit.
The R310 Unleashed (5Ghz) has a max throughput of 867 Mbit.
I have one location where a wired connection seems unrealistic.
What will be the realistic max speed to be achieved on the R310 unleashed, when meshing 1 hop?
If speed will be reduced by half (meshing), will it be realistic to expect the speed to be above 300 mbit (if coverage is high enough)? Or will you realistically never get those results?
