I've looked at some of the internals for some ruckus access points, specifically the 7000 series. What I can't seem to figure out is how the access point activates individual antenna elements. The antennas appear to be connected by one u.fl cable each. Does it use the u.fl cable to connect the entire antenna to the radio, while a controller on the board chooses an individual antennae element to power? Also, is there a way to determine the amount of antenna elements a ruckus AP is currently using or has, without physically looking at it? Is it in a log?
