After hard reset my R510 lost the SSID and the lan port was disabled...
After hard reset my R510 lost the SSID and only the SSID of the island appears, I can not access through the LAN port because it was disabled after resetting, everything seems to indicate that there was not a correct reset because only the power led turns on red and then it remains blinking green, can I access it through the SSID of the island to reconfigure it or should I discard it?
Comments
There are no comments yet
