vSZ-E with R510 - Maximum clients
Hello, based on
KBA-4666
I would like to know if anyone knows the values for R510 which doesn't appear on the table. I have a Virtual SmartZone Essentials with R510 APs, is that table applicable on this scenario?
It's likely to be similar to the R500 (which it replaced). However, i wouldn't recommend getting close to these amounts as you are likely to have operational issues before the you hit the AP limits
Thanks!
