I have an R510 with Unleashed 200.6 and R600 with Unleashed 200.7 connected to a Juniper SRX 240 firewall. The SRX has a DHCP server with reservation assigned for the APs' WAN but for some reason the IP address is being acquired and released multiple times. If I don't have reservation assigned the IP addresses will go from my subnet's low range and increasing around every 15-30 seconds.
I know I can always assign a static IP to the WAN address, but would like to correct this problem. I downloaded the logs and here's a snippet:
Aug 2 07:59:41 Ruckus-Unleashed-R510-b0 syslog: AP get the broadcast ip in its subnet, the broadcast ip is x.y.z.255
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, debug_init[82]: Set log_level file to [/tmp/pubnubd_loglevel].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd: set debug_log_level to 3, internal log_level to 1.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, main[729]: missing publish-key|subscribe-key|channel-name, pending service.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[644]: state change [(null)]->[PENDING].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[664]: 'Fri Aug 2 07:59:43 2019': service recovered
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pid=1160, monitor():FileCache synced
Aug 2 07:59:44 Ruckus-Unleashed-R510-b0 rsmd[86]: tacmon .......... [stopped] (0.020)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslogd (inetutils 1.4.0): restart (remote reception)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 sys_wrapper: Start Bind DHCP server
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslog: sqlited, adding AP group: 1, wlangrp_id[0]=1, wlangrp_id[1]=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: (ap state) AP begin to join ac.
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: Cannot notify kernel for Upd AP Param x.y.z.252(0) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 ZD-APMgr: Cannot notify kernel for Upd AP Param x.y.z.252(12225) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: WTP join cfm response, lwapp_notify_kernel_ip_addr [nat ipv4]. nat_ipv4_addr: x.y.z.252 port: 0 family: 2
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: System time was synced
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me, 4685 Failed to set set lbs port(parameter value out of range)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: eventd_to_syslog():AP[M:A:C:A:D:D] joins with uptime [132] s and last disconnected reason [AP Restart : power cycle]
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me: setting ip mode, before=1, now=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: [lwapp_update_wtp_vendor:7434] : company=4bss, strlen(company)=4
x.y.z.252 is the reserved IP. The problem is if I were to disable reservation I'd never login and obtain the logs before the WAN IP changes again.
I'd like to add that with reservation things work. All my VLANs (the WAN port is connected to a trunk and it's responding to the correct pool assigned to the port's PVID) and SSIDs all function. I've only tested with 1 client but it has internet access. I can also ping the APs by their reserved IPs even though after several minutes the address binding entry will disappear from the SRX. The DHCP server is fine--it works as expected with a Juniper AP and Windows notebook.
I have been troubleshooting on the R600 but since I have a brand new R510, I decided to see if it was an issue with the R600. The R510 was just configured using the setup wizard.
Thanks!
