How to create an SSID for selected APs above APs.?
How to create an SSID for selected APs above APs.? I have ZD100 and 7 ZF r300 APs. 3 SSID creates. Want to create an SSID for Specific 3 APs. Other SSID shows all APs.
After creating the intended WLAN (SSID), you have to creat a group of WLAN that content the created SSID, the cereat a group of APs that content your three APs and finally asign your AP group to your WLAN group. So it is done. The three APs will broadcast only your specifide SSID.
Thanks for your information.
