P300 power consumption
According to zone flex P300 specs sheet, it uses PoE only. If I'm going to plan for solar power for this equipment, how can I calculate its the power consumption? and also voltage rating? do I need Solar power PoE switch?
Solar charges a DC battery, then you need some kind of DC to AC tranceiver to power the PoE switch.
Maybe your local VAR or Ruckus SE has some experience/recommendations.
this doc might help -->
http://a030f85c1e25003d7609-b98377aee968aad08453374eb1df3398.r40.cf2.rackcdn.com/appnotes/appnote-so...
When using solar power watch out for the DC coming out of the Battery as new batteries will provide up to 15~16VDC (Had to use a 12V regulator on the output of the battery).
As for a 12VDC/220VAC, No solar power company recommended that solution.
From a personal opinion, solar power is the last option that you should consider..
