ZoneDirector
rescue mode help
Can anybody tell me how much time takes the process of recovery from rescue mode at ZD1100, I tried to do it many time following the instructions but after upload the firmware nothing happened.
Thank you in advance
Kind regards,
Hernan
ZD1100 rescue mode recovery (FDISK) should take less than 5-10 minutes, after
which you should be able to load a firmware image.
If you have tried multiple times without success, you may need to open a ticket and request an RMA.
sid_sok
One other thing to try. Download the oldest code you can find, 9.1.0.0.38 for example, to keep the software size as small as possible, then upgrade to the latest code, following the appropriate upgrade path of course.
