STA-DISASSOC-REASON[ieee80211_input(),2097,received IEEE80211_FC0_SUBTYPE_DISASSOC]10:08:b1:a0:9c:a1 rx_rssi=54,ack_rssi=0,reason=8,freq=2452,chan=9,rxpkt,byte;tx pkt,byte=(4712,1061152,75127,11654925).
I am also having this issue on a Virtual Smart Zone with R550 APsWe have 10 APs in the office for 100-150 people. Everyone uses Teams constantly and have complained about frequent disconnects, video artifacts, audio cutting out...all the hallmarks of a dropped connection.Recently a few co-workers were talking about the Internet access dropping, but the wifi stays connected and is only resolved by disconnecting from the wifi and reconnecting. I have personally experienced this as well.
We have a mixed environment, Apple, Lenovo, Dell, Windows 10 and 11, iOS, Android, Mac OSWe use Cisco switches, but I swapped them with Dell and Ubiquiti without any appreciable change.
Has anyone found a fix for this yet? Static channels? Longer background scanning times?I'll try about anything, they are coming after me with pitchforks.
If Wi-Fi clients are staying connected but experiencing connectivity issues, what fault-finding have you done on the other elements of the network and apps the users are accessing?
Static channels won't help if it's interference that's causing the issue, it will only exacerbate the problem. Longer background scanning will likely have the same effect.
Have you sought expert advice from your Ruckus partner to verify your SZ and network configuration?
december 2023. same issue mostly affecting apple devices and some laptops. androids seem to be working fine. wtf
Hi @hakunamatomato,
There is no such specific bug which may cause the issue with Apple devices.
If you are facing connectivity issues, we have to take a closer look at your controller/AP setup and verify what is causing the issue.
Since troubleshooting client connectivity could be complex sometimes, I suggest you open a case with RUCKUS Support and work with them.
