Hi there,
Currently we are using Ruckus R610 model Aps with Unleashed Controller version 200.8.10.3.290 now my company is planning to buy New Ruckus Aps R720 model so the existing controller will be able to detect and manage both Models.
Hi, You can refer to the release notes on the support site for the firmware you are using to see which APs are supported: https://support.ruckuswireless.com/documents?filter=82#sort=relevancy&f:@commonproducts=[Unleashed] In your scenario the R610 and R720 will work in the same environment.
Thanks will Test it..
Hi Faisal,
Yes, both APs are supported, as of 200.9 (latest version as of today).
200.8 also supports both AP models.
