ICX7450-48P Router(config)#lldp run
ICX7450-48P Router(config-if-e1000-1/1/5)#lldp advertise power-via-mdi ports ethernet 1/1/5
ICX7450-48P Router(config-if-e1000-1/1/5)#lldp advertise power-via-mdi ports all
ruckus# show ap mac
ruckus(config-ap)# lldp enable
Seeing the same issue—port 2 being an R710 and port 3 an R610. The R710 doesn’t appear to be doing LLDP by default. What my switch sees is below and this remains unchanged even after enabling lldp on the R710 as noted in another post here. The switch settings are the same for both ports.
switch(config)# sh lldp info remote-device 2 LLDP Remote Device Information Detailswitch(config)# sh lldp info remote-device 3 LLDP Remote Device Information Detail Local Port : 3 ChassisType : mac-address ChassisId : ... PortType : mac-address PortId : ... SysName : R610 System Descr : Ruckus R610 Multimedia Hotzone Wireless AP/SW Version: 20... PortDescr : eth0 Pvid : System Capabilities Supported : bridge, wlan-access-point, router System Capabilities Enabled : bridge, wlan-access-point Remote Management Address Type : ipv4 Address : ... Poe Plus Information Detail Poe Device Type : Type2 PD Power Source : Only PSE Power Priority : Unknown Requested Power Value : 25.0 Watts Actual Power Value : 25.0 Watts
### LLDP Info ###LLDP state: EnabledLLDP interval: 30LLDP holdtime: 120LLDP mgmt: EnabledLLDP bond type: Source MAC for LLDP frames on bond slaves: fixedLLDP poe: EnabledLLDP power: 25000LLDP interface:LLDP on eth0 : EnabledLLDP on eth1 : Enabled
Capabilities Supported: Capabilities, Network Policy, Location, Extended PSE, Inventory
I have the same issue. The issue started after updating the unleashed to 200.10 firmware. The issue is on the unleashed firmware 200.8 to 200.10. on the firmware 200.7 didn't get the warning of "Not enough electricity power provided with AP".
Tried several PoE switches and PoE injector but it doesn't resolve. only after downgrading the unleashed firmware to 200.7 its getting resolve. pls suggest.
@rajiv_kumar How it is impacting the network?
As per my understanding, functionality should not be impacted but throttled, depending upon provided POE power to the AP.
Try to set the AP power manually from Unleashed GUI, set to the highest supported power as per your switch/POE injector. See if that fixes the issue.
We were seeing this same issue, and change the solution for us was also forcing the AP running PoE to switch the mode from "Auto" to 802.3at PoE". Thanks for the tip George.
Thanks.
It works
@syamantak_omer, thank you, this solved the problem with my R610 which should not be a problem.
Cheers,Casper
Sadly this is still an issue with my R720 and Brocade ICX6450. Even manually enabling 802.3AT mode on the AP it still functions at 802.AF power levels. I've tried enabling LLDP on both the switch and AP to no avail. Really frustrating.
Hi Nick,
R720 supports 3 power modes, AF/AT/PoH.
If you have configured it on at, you may still get alert, however, as long as AP is getting AT power, it should function just fine.
SSH into the AP and run below command to check the status.
get power-mode
Just saw this thread after I started one regarding what switches are actually compatible with Ruckus because no switch I've tried will negotiate with the R850's and I can see them only drawing 11-12 watts. Performance is absolutely horrific and nothing I've tried will actually get them to use more power (on Unleashed 200.10). Sure I can set them to force bt power, but they don't actually do anything other than make the warning disappear. Power still sits at 11 watts. Happens on a Dell N3200 switch and a Cisco SG350X-48MP switch. Both have more then enough power, the APs just refuses to use it. Given the amount of threads regarding poor performance with the later APs, I'm starting to think the underlying issue is because these AP's are not negotiating power correctly.
