Model[r510] is not supported; connection request from AP[xx] refused
Hey everyone,
I purchased a ZD1200 controller to manage 3 R510 APs and I keep getting this message. Support mentioned to reupload same firmware file to the controller (currently 9.9). I've done that and to 9.12 with no luck.
Any suggestions?
jeremy_pierce_6
If I am right you need to do some of the middle firmware. It doesn't let
you jump from certain ones, especially older ones to the new one. On
the support page it should let you get to some of the other ones. If you
look on the release notes it will tell you which ones you can skip.
john_d
R510 requires 9.13 MR1, I believe.
John D is spot on 9.12 does not support R510, 9.13 does.
