Hi Mark,
I updated a knowledge base article, that will appear on Support after the next every 6hr update period.
https://support.ruckuswireless.com/answers/000001391
Root Cause:
The reason for this issue is that wireless printers do not do webauth. On a Guest WLAN the clients are redirected before they are allowed access, even when there is no authentication on the WLAN there is a redirect that happens. Hence printers will not be able to authenticate and connect successfully.
Workaround:
Create a WLAN with WPA-PSK or Open type authentication, and connect the printer or other non HTTP capable guest resource.
Resolution:
Use a Non-Webauth WLAN on the Guest Access VLAN for non-webauth capable guest resources.1. Create a Standard WLAN with WPA PSK,2. Connect the printer on this WLAN. - Most printers will work with open and WPA enabled WLAN's. - WPA2/AES combination is prefered if the printer/device supports it. For the above scenario, if the Guest user's are placed on a VLAN, then we can allow them toaccess the printer by creating a Standard WLAN (with/without auth), tagged with the sameVLAN as the Guest user's.After connecting the printer to this WLAN on the same VLAN, the Guest user's will be able toaccess the printer/other resource. If a customer wants Full Client Isolation enabled on the Guest WLAN, they will have to allowthe printer's IP address under Restricted Subnets (eg: 192.168.2.25/32 - this /32 host addressallows only this single IP) to permit/allow the Guests access to the device.
