RUCKUS EOL Products
SmartCell Access Points
Using AP to Captive portal redirection with SoftGRE
Hi all,
How to use captive portal redirection from the AP while having data tunneled to Cisco ASR1400 with SoftGRE? In the vSZ configuration, softGRE tunneling option should be disabled to have HotSpot WISPr authentication?
Pamuditha
No.. I dont' think so, from my last conversation with Eng.
Hi Michael,
Thanks. Then the solution will be portal redirection happened at WAG. Is it? If so there is no use of using SCI since vSZ do not have client level visibility?
