I'm trying to install Speed flex in a device with Android 4.3, I try to search using the Google Play but I can't find it.
then I decided to go to the ruckus web page and from there try to install it, when I try to install it say that the device is not compatible with the app.
I already have the ZD Remotee app installed , so why can't I install the speed Flex?
Can you help?
regards
Pedro
