Tx Power settings in ZD
Hello guys,
I have several Ruckus ZoneFlex R510 APs. I want to know mW equivalent, if I will set TX power settings to -8dB in ZD for both bands. Thanks in advance
I'm looking for an answer on this for some time.
Will it decrees it from the max radio power output of the model?
Or will it decrease it from the max power output based on the regulatory domain?
it is an attenuation from the the max EIRP allowed in your region. (it is specifed it with the Country Code)
Thx for your response
So I'm in Europe and here maximum indoor allowance is 100 mW. So if I not mistaken 100mW in the 2.4GHz equal approx 20 dBm. Should I calculate - 7db from Maximum EIRP, correct or I'm wrong? For ex: 20db - 7db = 13db
Yes, if you want to have 13dBm (20mW) EIRP you should set Tx Power Adjustment to -7dBm
and how does that work with max EIRP on difference channels on 5ghz?
If the AP decides to change channel to 100 from 36 then the max EIRP will change also and the cell size will change as well.
Is that correct?
Hi Andrew,
Please open a support ticket with this requirement, as support has access to Shell of the AP they should be able to give you a straight answer not less than in 30 mins.
Abilash PR.
